1985 Monte SS drag car build
DysonSS
145
281
Littleton NH
Ford 8.8 is an option as well. Might be a little more budget friendly. Either fox body or like a Lincoln town car I believe fit. Companies make kits for the swap.plus the 8.8 has tone of aftermarket options. They're plenty tough
I have read that other places too. It’s to bad I had a spare fox body rear end I sold a while back. Left over parts from my old GT. I might be able to get my hands on one cheap a buddy of mine has a notch back drift car he has a ton of spare parts.
bracketchev1221
1,406
1,644
Nhra rule is 6 point roll bar at 11.49. And yes it has to go through to the frame. Make the rear down bars weld over the rear spring seats.
bob64
713
674
Niagara Falls, Canada
1/8" is pretty light, it may pull/twist a little for pads, l used 1/4". Even when l boxed the frame l used 1/4" but alot of people do box with 1/8".
My Engine is built to handle 1500hp at the crank. I still haven't figured out if l want blower or turbos.
I guess the point l'm trying to get across is plan for the future builds, cause we'll always want more once we get use to one thing.
bracketchev1221
1,406
1,644
1/8" is pretty light, it may pull/twist a little, l used 1/4". Even when l boxed the frame l used 1/4" but alot of people do box with 1/8".
1/8” plate is fine for boxing the frame. 1/8” plate is heavier than the metal the frame is made out of. And a true cage stiffens the car up by tying the front boxed frame to the rear boxed frame.
DysonSS
145
281
Littleton NH
Got one side done
DysonSS
145
281
Littleton NH
Got the other side done. There is more clearance on the passenger side that’s how it was from the factory. I didn’t want to take to much out on the drivers but there is still enough room to clear the 295/50 on a 15x10 weld draglites with 5.5” of backspacing. I’d like to use the Nitto 555 325/50/15 but they may be to much.
DysonSS
145
281
Littleton NH
Got some goodies in the mail today!!! Correct 1985 bulkhead wiring harnesses and the drivers rear body mount support. Thank you everyone for your suggestions so far. The gbody forum has been extremely helpful and full of good info.
DysonSS
145
281
Littleton NH
Got started on boxing the c channels and welding up some of the seams yesterday. I also got one repair washer welded in 3 more to go.
