I have a TPI unit off of an 85 iRoc Camaro I would like to stick on the 305 that’s in my 88 Monte Carlo running the fuel system from the tank forward I can manage and the installation the thing is I don’t want to use a painless wiring harness with prom type computer I wanna tunable EFI what have you guys used and recommend I do for the swap
Thanks
1320john
MegaSquirt 2 with a relay board. It's made for TPI and TBI. Extremely tuneable , but definitely need a laptop. $700-800 in assembled versions (recommended) for everything you should need. We ran the system I'm describing on a 327 with TPI for years without and with a turbo, and for a single year with the Motown LS with multiport Edelbrock intake and factory 8 pin HEI. The setup is very straight forward. It will do everything that a TPI requires. If interested I can explain further - wiring it is quite simple - diagrams readily available in color. Support of the system is better than Holley's.
There are a couple of things that an MS2 does not do easily, such as swap to coil packs and go sequential injection, neither of which is needed for a basic factory TPI setup. There are no hidden fees or costs to the software. And it is very reliable.
I'm a believer in this stuff - a '78 280Z with a factory 280ZX turbo motor ran by an MS1 for past 3 years; '68 Austin Healey factory motor with Ninja TB with a Microsquirt (still working on car), MS2 is being installed back onto the 327 in '67 C20 - hopefully ready for spring or early summer, MS3X on Motown LS with turbo, multiport, coil packs, boost control, launch control, traction control, table switching for having multiple tunes loaded for different fuels running 2 fans, vacuum pump and meth injection for past two years.
All of these installed and tuned at 'the top of the hill'
