Sometimes you just don’t want to deal with the stuff you’ve collected and just heaveHope you don't hate me, but had a set collecting dust. Finally tossed about 4 yrs ago.
I'm going to have to dig out the set I pulled from a Caddy D-body to see if those are the p/n's on them. Might be good for the OP.Just an FYI, in 1979, they started with a first design, and then swapped sometime in the model year to a 2nd design, which was used from then on out on the A/G-body. I don't know what the differences were. Just going by parts info.
Good thing is, RWD 88, RWD 98 body used the same p/n for the housing, lens and housing gaskets on the fenders. Maybe even FWD Oldses too. Not sure about the other stuff that goes with it, though.
The RH housing p/n is 563552 and the gasket is p/n 563384.
D-body Caddy 84-89 calls for 1617260 for either side, gasket "N.S.". Must be flat as Kansas on those caddy fenders.I'm going to have to dig out the set I pulled from a Caddy D-body to see if those are the p/n's on them. Might be good for the OP.
