BUILD THREAD 1986 cutlass supreme brougham 2 door "Godzilla" the anti Ls movement lol
L67ss
1,350
420
Been thinking over the build plan and think I'll change some of them. Recently got a job at a junkyard so parts will be a Lil easier. After figuring out a junkyard driveshaft that I have access to that will allow me to swap without cutting I will likely go with a 700r4. Can get cheap plus the mounting will be sorted for my eventual t56 swap. Instead of a 9" I'm going off nailheads info and using s10 axles to swap in a 28 splint carrier and lower gears into my stock axle. Will be going blazer 4 wheel disc. The Taurus seats have lost their appeal so I'll be swapping to either 88 iroc buckets or 1975 cutlass buckets. Further down the road I will be looking at some engine setback
L67ss
1,350
420
Scored a 700r4 shifter and a set of 88 camaro seats(different set). Stay down plate bracket from f body. Rear speakers.
L67ss
1,350
420
Worked a trade for blazer 4 wheels disc brake and spindle setup, 28 spline axles, and a 3.42 gear setup
L67ss
1,350
420
Quarter inch longer. Ill need a spacer between housing and backing plate but I have a friend with a lathe. I had to get rid of those 2.14 gears currently in the car lol
Clutch
5,189
10,913
Brick NJ
When you do that can you post some pictures? I'd like to see how it's done
L67ss
1,350
420
So before taking ownership of the open dif 3.42 setup I found out the same guy had a 3.73 posi setup laying around. He was down for substitution of parts. Also he let me know of a 403 swapped 83 turbo regal he had in semi secret storage. Unfornately he has circle track plans for it but I'll likely be able to score the removed parts in exchange for helping to set it up
L67ss
1,350
420
Officially own the 3.73 posi setup now :)
