BUILD THREAD 1987 Monte Carlo from Iceland
O. D. Showtime
3,007
3,528
Regina Sask. Canada
Just got caught up...nice progress! Good to see it sitting on the frame.
9,167
15,344
thanks man, yea for myself it is a real relief... and I surprise myself sometimes, all this work in one week, but it's been 40 weeks since I started this project! haha
You're on a better schedule than me, it's been over 10 years & I still haven't finish the current build.:( Now that I'm on my unscheduled vacation/holiday I have to put anything that cost on hold.
Sævar Örn Eiríksson
136
574
ICELAND
How does the rear of car attach to rotisserie?
Hi, thanks for asking, it's not a conventional way of attaching a rotisserie to a car at all.. Usually you would use the body mounts to attach the rotisserie to, but then again, I had no such body mounts... they were all gone.
There was only one way to do this really, lay on my back and fix these body mounts prior to attaching the rotisserie, with sparks flying down my face and weld spatters in my ears(i'm never doing that again...)
Or the other way, which I quickly decided to do, make a clamp around the trunk body and clamp the sheetmetal fastening it to the rotisserie at the correct weight-balance so the car can be rolled by hand, this was a difficult calculation and I got it surprisingly correct..!
I don't have any great photos of this attachment, except for those in page 1 of this thread, I'll repost them here for you, and again, this is by no means a recommended way of attaching a car body to a rotisserie
These are the body mount braces I had in the body, they were completely gone
The front body mounts were the same, so I used the door hinge supports
In this photo you can kind of see how I clamped the trunk body between two thick pieces of flat steel
Here's the rotisserie after I removed it yesterday, it worked very smoothly and rolled easily
Another photo shows the rear attachment
and finally the last photo I have of the attachment, I'll take another photo tomorrow from the inside of the trunk, I did some additional bracing from the clamp on the inside of the trunk body to the trunk floor, just for safety, this all held up great and there is no sign of any movement
Sævar Örn Eiríksson
136
574
ICELAND
this would be the inside of the trunk, just to prevent the sheet metal of the trunk to rip apart and move on the joints, and I'm glad I did this because it all worked good, nothing moved or cracked not even paint peeled at the seams so it was done right given the circumstances.
today mostly was cleanup day at the shop, this sparks motivation too, as I've been dreading the cleanup, but having the car in two piles now, instead of 7 piles makes me feel more motivated to spend time at the shop !
My girlfriend is always a great help when it comes to cleaning at the shop, organizing tools and shelves and fasteners, she loves it, each to her own I guess... I throw my tools away where I stand and move on, hehe...
This toolbox has had >30 things on top of it since may last year... now it just needs a bath and it will look new !
The worktable, it's there after all..! I haven't seen it for a while..!
I had to make a few minor changes in the angle of the rear frame rail sections, they were hanging a little low so there was about two inches of gap between the body mount bushes and the nuts in the body, one inch was just swaying of the frame from being hung from the 2 post lift, but if I bolted it together with the other inch aswell there would have been binding in the body.
We don't want that on our rust prone and weak body so I changed the angle of the frame and now the body sits resting on the body mount bushes, no tension anywhere all bolts screw in by hand and the body perfectly centered on the frame...
this is evident around the rear section where the bumper crash bumps go where there is very little clearance from the inner fenders, and also near the rocker panels where there is only a fingers' gap between it and the frame.
I'm very pleased with the fitment of the body after all this welding and eyeballing, because there was hardly anything to take reference from in the beginning, everything was rusted or out of place to begin with...
Now I'm not safe yet, I still have to fit the doors to the car... if they fit good I'll be very happy, but I'm also prepared that some mending will be needed to get them fitting perfectly, so be it, it's only metal... play dough really.
On that note, the doors are ruined! Simply buying the outer skin will not be enough, I'll have to buy the two doors along with the door frames new! But that will wait until summer, it's arpimd 1300 bucks with shipping, aftermarket.
Reactions: 7 users
Clutch
5,189
10,913
Brick NJ
Wow your cruising through that project! Would it be cheaper to get a good set of original doors? They usually fit better than aftermarket anyway.
PBGBodyFan
792
1,223
Wisconsin
Glad to see you are back at it, lookin' good.
I do have a set of spotless doors, 81-85 mirror location though in case that matters, fresh from California Also not sure about shipping them :unsure:
