1987 TBI 454 Suburban... It Runs! Kinda.
MrSony
MrSony
4,597
2,868
Des Moines, Iowa
Nope no code if there’s not enough fuel psi but it could cause other codes you really need a good scann tool to see what is going on it’s to bad you weren’t closer I have my old snap on brick yet and use it once in a while for stuff like this
I mean... I did to it the cheap way. With a paper clip. But if the scan tool lets me view a live readout of whats happening for that 30 seconds it'd be nice to have.
Gonzo1970
Gonzo1970
342
354
spicercars
spicercars
Jan 7, 2019
99
50
Saginaw MN
If it's running that rich, I'd put a coolant sensor in first for all the reasons given (I don't think that would throw a code).
Think I've heard that before.
DRIVEN
DRIVEN
5,498
4,911
Owyhee County
Yes. Codes are only set/stored if the ECM sees values outside of a given range. Example: If the operating range of a sensor is 1-10, it doesn't recognize a fault unless it sees 0 (say, shorted) or >11 (open circuit). The CTS is a good example for this since corrosion can cause it to see -38* so it adds buckets of fuel because it thinks it's at the south pole. Hypothetical range being -140* to 300*. It's not at a 0 or 11, just at .03 so no codes set. Make sense?
Sure, codes are valuable but so is raw data. Not saying for sure that CTS is your problem, but it's a likely suspect given your description.
8
81cutlass
1,626
2,326
Western MN
I had a coolant temp sensor go bad on my firebird 3800. It would start but run very poorly and die easily. Stumble, miss, ect. No check engine lights. I hooked my HPtuners up to it and low and behold the coolant temp sensor was stuck at -38° and dumping fuel. If I didnt have a scanner I wouldn't have known.
69hurstolds
69hurstolds
1,591
2,127
Oh, yeah. My bad. Get one that does both then. Cover all the bases.
When spending other people's money, you don't pay attention to details.
TURNA
TURNA
7,010
9,247
Socialist NY
This may sound nuts but check your battery ground cable.
Over the last 2 days after work I did a Nissan Altima
Running like poop, misfiring, stalling.
Was going crazy chasing coils plug sensors and codes only to find the battery ground able was hanging on by one copper strand.
I cant believe it even started.
Cable replaced runs like new.
MrSony
MrSony
4,597
2,868
Des Moines, Iowa
Replaced the coolant sensor, no change.
Similar threads
