1987Cutlass tires rubbing the control arms
jmcghee
10
I have an 87 Cutlass with 215/65/15's mounted on 15x7 SS111 Olds wheels , The front tiresare rubbing the back of the lower control arms, on turns with a bump. Does this mean the front springs are wornout? Car has 150.000. Or is somethingelse going on?
ck80
Moderator
Moderator
5,745
9,123
What exactly did the wheels come off of? Originals or reproductions?
The reason I ask is not all super stock rims were the same. Appearance-wise the center hub sections were the same, amd even some of the barrel lips were, but, backspacing varied between original, reproductions, and what the older a-bodies got vs the gbodies differs too.
I forget all the exact measurements, but, I do remember that much from when I used to swap meet hunt rims for rims 30 years ago
jmcghee
10
Tirea are rubbing. Tires and wheels are tthe exact spec as a 442
jmcghee
10
ck80 had the answer not all 15x7 ss111 have the same backspacing the 74 wheels are 4.25" the 87 15x7 wheels had 4" the 14x6 had 3.5 theres the rub
SS_Malibu
1,150
2,006
Mesa, AZ
If your wheel lugs are long enough, while not ideal, a quarter inch spacer would correct that as long as it doesn't push the wheel out far enough to cause rubbing on the outside of the tire at the fender area.
