1988 Monte Carlo LS ProCharger Build (10/12/21 - Back to Painting, Switching directions for power added)
Tony1968
2,324
5,132
NW Indiana
If you need the frame add on for the Holley 4l80e crossmember don't buy it
I have one that I didn't need because of the Hellwig frame boxing I did. I'll make you a great deal on it
  • Winner
Burning
182
647
Bardstown, KY
I appreciate the offer, I am sending the frame to get boxed in and braced by a company here in Louisville. By boxing in the frame does it get rid of the necessity to use that extension?
Tony1968
2,324
5,132
NW Indiana
It might but it depends on what trans was originally in the car from the factory. I believe the 200r trans frame doesn't need the extensions
Tony1968
2,324
5,132
NW Indiana
I'd just give the new trans cross member to the guys doing your boxing and they could add what is needed via fabrication
Burning
182
647
Bardstown, KY
it was a originally a 200r trans car, so I’m pretty sure it’s already there.
Did you like the Hellwig kit? I thought about supplying the parts for the box kit but I’m sure those guys can cut metal and get it to work too.
Tony1968
2,324
5,132
NW Indiana
The Hellwig kit is way more than just closing up the C channel. It wraps entirely around the frame. It's much more rigid by far. As weak as these frames are from the factory i deemed it necessary for my build anyway.
Burning
182
647
Bardstown, KY
Probably save me some coins if i did that myself and then had them weld in all the chassis bracing that i'm looking at doing. May be overkill, but i want to do it right and do it once.
Looking at doing something similar to this.
Along with the torque boxes being reinforced, and along the frame where i will be notching.
Ordered a bunch of sanding discs, and some purple roloc discs now that rktpwrd has shown me how bad *ss they are! Those should be coming today which will get me started on getting the rest of the body panels that i see damage stripped down to bare metal. Im also going down to TN this weekend to strip some parts and some metal from a gbody i have found.
Reactions: 5 users
Burning
182
647
Bardstown, KY
Been lacking on the updates as i have been fighting the car! lol
Got my go fast goodies in! Kinda put the cart before the horse but i need these for mock-up. I splurged a little bit on this as i knew later on i would likely be moving up to a Forced Inductions s480 billet wheel turbo and wanted to make sure i wouldnt have to upgrade these parts again. Got my stainless 3" pipes for the hotside, turbo flange and t4 merge stainless pipe in. As soon as the Holley turbo manifolds come in i can start on the hotside.
TurboSmart 60MM Powergate, as you can see she isnt tiny! 7lb spring in it, ill be controlling the wastegate with c02 so i can go basically 7 psi up to whatever i would like if i pin the gate shut with air lol
TurboSmart 50mm RacePort BOV
The Holley Term X Max came in, may be selling the ecu as I am unsure if it will be enough capabilities for what i want. There are quite the limitations when compared to the Dominator ecu. I have the Dominator previously and loved it.
Ended up finding a car down in TN that i cut the roof out of and gabbed what i needed for some interior parts and began stripping it down and removing the skin so i could patch it back on my car.
Then attempted to patch on my own. Quickly realized i am not cut out for it, but i am working through it! Rktpwrd has been a huge help answering all my tedious amateur questions!
You can see here the line had sunk about 1/8" or so. Need to order a unispotter and slide hammer so i can try and pull it out.
Followed Rktpwrd and filled in where the lead seam was on the roof edge. I still need to fill the cut edge on the inside and get it to fit perfect with trim.
Got the next section cut where i need the patch to go, will final cut it when i get time this week.
Also i decided to switch mounts and go from the ICT Billet adapters with stock clam-shells to the Holley mounts with Holley clam-shells and poly inserts. Ended up tearing the whole front end apart since it will have to be replaced sometime anyways. Need to figure out what suspension kit to go with. Kinda looking for a jack of all trades setup. Not perfect at anything but can do everything decently!
Threw the 80e on the motor since i scored it from the JY for 100 bucks. Threw it in the car with the truck pan and the pan hits the crossmember. LOL
So now i am on the hunt for a Holley 302-2 pan or equivalent!
  • Winner
Reactions: 6 users
