1991 Dodge AC
xylorex
xylorex
126
New Orleans, LA
My father-in-law acquired a 1991 Dodge Spirit R/T (2.2 liter twin cam, 4 valve per cylinder, intercooled turbo, 5-speed getrag).
He brought it over for me to do some work to, I've knocked about everything out except for the air conditioning. I have replaced ever component except for the hoses, can't get it to cool... What the lines do is get hot as hell! I've tried r-134a first (originally r-12 system), then when I had no luck with that I tried r-12a. Never had one give me this much trouble.
My question is -- have any of you experienced a hose causing these symptoms?
Thanks
xylorex
xylorex
126
New Orleans, LA
Guys, I know the topic isn't sexy being a 4 cylinder dodge and all... But i would appreciate it if a few of you could chime in on your experience with AC hose failures.
not leaking failures, but whats happened to you when the interior of an AC hose has failed / deteriorated.
DRIVEN
DRIVEN
6,152
Owyhee County
What are the gauge pressures?
Turbolq4
Turbolq4
1,466
Nampa Idaho
I thought those were single cam?? I'm no help on the a/c front, sorry.
xylorex
xylorex
126
New Orleans, LA
thanks for your reply driven.
to be honest i don't remember exactly what the low to high side ratio was... but the compressor is new and working.
however i did several times pull vacuum for 2+ hours and re-charge up to 20psi or so and slowly add until about 40 psi on the low side. around the upper end of this range the line would get "cool", but not enough to produce any condensation (charging with my hand on the low size). then i would slowly bleed off a little at a time to try and find a sweet spot (usually 15psi or so), but after this the line temperature just keeps getting hotter and hotter no matter how much i add or remove. (recirc on/ blower motor on high / ~1200 rpm / squirrel cage fan blowing in front of condenser)
so, i thought that maybe it was the metering valve... i thought that perhaps since it was designed for r12 that the r134a wasn't flashing. i changed the dryer and pulled vacuum on it for several hours. did same procedure as above for the r12a but had the same result.
i've done the r134a probably 3 or 4 different times, and the r12a twice. kinda tired of throwing cash around at it!!
DRIVEN
DRIVEN
6,152
Owyhee County
Sounds like you covered most of it. My limited experience with conversions is that they take about 80% R134 vs R12.
Maybe a stupid question; is the cooling fan cycling?
xylorex
xylorex
126
New Orleans, LA
Yes, the electric fan comes on when the AC compressor clutch is energized
DRIVEN
DRIVEN
6,152
Owyhee County
Since you're listing PSI, I assume you're not charging by weight, correct? If so, that's always tough to dial in. If your oil spec is close, the compressor itself shouldn't get very warm but H line will. I'd think 140-ish. L line should be cold to the touch.
I kind of suspect you're under filling but without knowing the weight of the charge or seeing gauge readings, that's only a guess.
Sorry if that's vague. AC is one of those things that's tough to diag via keyboard. Here's a little cheat sheet if you don't already have one.
Reactions: fleming442
Thread starter Similar threads Forum Replies Date
Mr.1980 Non-G Projects 4
