OLDS 1991 Oldsmobile 98 Running Rich
Mr.1980
Mr.1980
:worthless:First off I know this car isn't a G-Body Oldsmobile I know it's a C-Body but I'm just looking for some insight. It's a 1991 Oldsmobile 98 Regency-Elite with 3.8L GM 3800 engine; I recently purchased it for a steal it had 3 problems though.
1. Every Brake Line Needed Replacement
2. Check Engine Light Illuminated
3. ABS Light Illuminated
First I replaced every single brake line and I mean every brake line, I also replaced the front Calipers, Pads, Rotors and Rubber Brake Hoses; I also replaced the Drums, Shoes & Hardware, and Wheel Cylinders and did a full brake flush with the BG machine. This thing stops on a dime. So then I used my nice GM Tech 1 and scanned the ECM and Chassis for codes. I received as follows:
ECM Codes:
41 - Cam Sensor
42- Ignition Module
65 - Oxygen Sensor Detect Running Rich
ABS Codes:
A031 - Right Rear Speed Sensor Circuit Open
So I replaced the Cam Sensor, Ignition Module and Ignition Coil, Oxygen Sensor, and Right Rear Wheel Hub and Bearing with the ABS Sensor. Started the car both lights still illuminated so I scanned the car again ECM codes for the Cam Sensor and Ignition Module were gone but the Code 65 was still present upon further research on All-Data for Code 65 I found that in addition to a faulty oxygen sensor it could also be a faulty Fuel Pressure Regulator or Faulty Fuel Injector I replaced the Fuel Pressure Regulator check engine light is still on and still pulls code 65 but there's no black exhaust smoke or rich fuel (rotten egg) smell. As for the ABS Code after replacing the R/R Speed Sensor/Hub the Tech 1 not only still pulls the A031 code for the R/R Speed Sensor but now has a code for the L/F Speed Sensor Circuit Open which it initially didn't have. So I'm looking for thoughts on both. I'm thinking the Check Engine Light is staying at Code 65 for any of the following:
Fuel Injectors
EGR Valve
MAP Sensor
As for the ABS Light I'm at a loss I don't know if it really needs a L/F Speed Sensor or if it's an ABS Regulator or even the ABS Module & Pump Assembly. Or you if it could even be an actual computer ECM problem.
1bad79
1bad79
1,001
Allendale mi
The fuel injectors are easy they need to be about 12.6 ohms when warm,newer stuff you can fire each injector with a gauge hooked up to see what they do I don’t think obd1 has that capability but make sure your fuel psi is with in spec I can’t remember what the voltage you see on the map at idle but I’m sure someone here will chime in with it the regulators used to fail where they suck fuel in to the intake but if you replaced it make sure you have adequate vacuum to it
Reactions: Texas82GP
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
27,203
Kitchener, Ontario
oh oh, another running rich problem. MrSony went 110 pages before he decided to yank the engine......:popcorn:
Reactions: fleming442
