What are you guys using for the lower rad hose that has a 2" port on the radiator? The store I used to head to to get my hoses that had a wall that I could pick from is closed and like you all know unless you know the car, model, year and last time you went through a coffee drive through the guys behind the counter give you the
That sounds really big. A lot of the aftermarket stuff is 1.5". I know the lower hose I have on my 88 is 2" on one end at the water pump and 1.75" due to having the wider and larger 70 rad in there that took some cutting to fit. I bet it might fit after trimming but the Olds V8 probably has a different outlet angle.
