To remove as an assembly.
Not sure which G-body you have so I'll describe Regal since that is what I have.
Remove radiator.
Remove front bumper
Unplug all lights and pull wiring out of front clip parts.
Unhook hood latch cable
Remove battery
Depending on options you will need to unhook or remove accessories on inner fender wells. (ie cruise, washer bottle, relay block, etc)
2 bolts lower radiator support.
1 top bolt each side by hinges.
1 bolt each side inside door near top hinge.
1 bolt each side inside door near bottom hinge.
1 bolt each side underneath rear of fender just in front of door.
1 bolt each side in the wheel well.
Remove wheels is not required but can help for more space.
NOTE: keep track of # of and thickness of shims under each bolt for reassembly (Very Important!)
Depending on which G you have there are some small variances, but this is the main list.
At this point you will need help, it can be done with two people, but much easier with 3 due to size of assembly. Pull entire assembly forward a little bit, then should be able to lift up and out of the way.
and no do not need remove glass.
