i know i asked awhile ago and no one really had any answers so not expecting a miracle since thisnt isnt so much of a transmission board as it is mod,engine rebuild and swap so if anyone has any advice on a site i should look into id be very appriciative.anyway if anyone knows when adjusting the tv system on the 200-4r and your looking through the tv sight hole is it supposed to be between the two notches of the tv valve completely untouched or when loaded as it is when the throttle valve cable is set into place and adjusted.i know it wants to be dead center on the tv valve i just dont know if its supposed to be under slight load(i.e. when the pressure is put on by the throttle valve being hooked up and adjusted at the carb) or if its supposed to be dead center fully extended.any help would be awesome
