200-4R Help
V8 Rumble
1,290
585
Connecticut
The direct drum is .010 per clutch. So if you have 6 clutches for example it should be .060. This is checked between the snap ring and top plate
Forward clutch should be between .030 and .050 between the top plate and snap ring when applying about 20 lbs of pressure on the top plate.
4th drum and lo-reverse no specs shown in my atsg manual.
