200 4R swap
dedub
209
12
N.C. Fort Bragg
I'm about to transition from a TH-350 to the 2004R. I've got just about everything else sorted except one thing... the TV cable location. Attached is a photo of my current linkage with the kickdown cable. Does the TV cable have the same mounting point on the linkage? Is the geometry the same? Do I need a separate attachment or linkage for the new cable?
melloelky
4,161
9,568
mass
that Holley bracket is the one to get.i can't see enough of your cable to determine if it's the correct adjustable one or not but having the rite one is super important.
dedub
209
12
N.C. Fort Bragg
Here is a better photo, my bracket is 100% universal which probably isn't a good thing. I think I'll get the Holley one. The good think is I now know that it goes to the same location on the linkage.
565bbchevy
9,614
12,683
Michigan
I use this style linkage bracket on all of my Holley carbs, the cheap metal universal ones tend to flex and shift.
Mac442
257
384
Ocean County, NJ
OP I think you’ll need the Holley bracket and correct TV cable. These trannys are finicky and need the TV set exactly. Don’t take any chances with the cable or you’ll burn up the trans.
dedub
209
12
N.C. Fort Bragg
565bbchevy
9,614
12,683
Michigan
I like your bracket, is that a Holley bracket? What part# ?
I think I bought the bracket from Jegs (brand) and another brand for the kickdown piece
