200-4r transmission cooler line threads?
techg8
techg8
470
I want to change from solid cooler lines to -AN fittings and braided hose.
Does anyone know offhand the correct threads/sizes?
In the trans case? Or the flare sizes? are they the same in the radiator?
Thanks for any help. Off to scour the internet for answers.....
fleming442
fleming442
8,512
melloelky
melloelky
1,701
mass
the correct adapter to make this happen is -6 AN to 1/4 in. NPSM Straight Thread NOT npt.that's a common mistake.For the radiator end 1/2" 20 thread with an inverted flare.
TURNA
TURNA
9,793
Socialist NY
the Transmission Cooler Lines to Case, -6 AN to 1/4 in. NPSM Straight Thread, NOT npt.that's a common mistake.For the radiator end 1/2" 20 thread with an inverted flare.
Are you say the trans case itself has -6 AN threads tapped into it?
  • Useful
Reactions: melloelky
melloelky
melloelky
1,701
mass
:doh:good point,no i should've said the correct adaptor to make this happen is -6 AN to 1/4 in. NPSM Straight Thread
TURNA
TURNA
9,793
Socialist NY
OK so the factory fitting female end that is screwed into the case is 1/4 in. NPSM?
DROLDS84
DROLDS84
322
SW Michigan
I had a fan cooled transmission cooler in my Hurst and I remember ordering some special brass fittings like Turnas pic...you can't find them anywhere...went to some special place to get them...would measure for you but transmission is out to get rebuilt
techg8
techg8
470
Good info guys, thanks.
I just placed an order for adapters, hose ends and hose at Summit. $125ish all told.
I went with 15' of hose, figuring on a maximum of 7ft each hose if I ran from the trans to the frame rail then forward. I would rather have excess than not enough.
IF it could be routed such that the hose follows the original hard line path, one might get away with 5ft each line. This might require 90deg or 45deg fittings.....
Reactions: TURNA
