2002 GTP No low beams ?
20,391
blown relay, the DRL's use the high beam
I borrowed this ...
fuse box labeled #35 DCM Module
ACDELCO Part # 15016745 Main Relay
20,391
that part number is the relay for the low beams so we just need to find where it is....
antonC4Gbody
15
17
arizona
Hopefully someone can steer me in the right direction here. My 2002 GTP, I have no low beams but the DRLs work and the high beams work just no low beams. I check all the fuses and swapped bulbs but still nothing. Any suggestions...
it your light switch i have one go out on me none of the lights worked at all it plastic junk
20,391
I assume you checked the #3 fuse to make sure it's not blown and all the contact points are clean. I am surprised your fuse box contains no head light relay, the Grand Prix's before and after your's used a relay.
Onehit
233
395
Old Bridge, New Jersey
After digging around for a bit it comes down to the "Multifunction Switch" went bad. Its kind of a common issue after I Googled the cheap out of it for a while. I had them on for a little bit last night after flashing the highs on and off a few times real fast then this morning out again.
I found a new one already for $60 but I saw prices of over $300 for the same part. Rockauto has them ranging from 130 to 260. Amazing how prices fluctuate.
