2004R
Street Sweeper22
145
I tried searching all the forums for information about upgrading my 3 speed to a 2004R. So if this question has been covered I apologize How hard is it to put a 2004R in my 84 Regal that currently has the stock 3 speed?
stew86MCSS396
Aug 1, 2022
81
(808)
Your '84 should have the extension piece welded in on the driver side that accepts the 2004R crossmember which is what you need. Same length so same driveshaft. There's a metal plate with "PRNOD321" that installs over the "PRND21." The TV cable that attaches to the carb adjustment is critical. gbodyforum+200-4r+swap
Street Sweeper22
Thread starter
Nov 18, 2017
145
I have a néw double hump cross member and I had to unhook the cable that runs the gear selector to get my hand controls to fit so I just go by feel. I got a new tv cable and I watched a few videos on it. I feel pretty confident on that one. Time will tell, right lol. Thank you for your input. If you think of anything else let me know. Your help is appreciated
nycutlass
415
NY
the hardest part to the whole swap is getting the tv cable right and stay calibrated correctly that means keeping a eye on it and time to time adjusting it if the cable stretched
8,254
Melville,Saskatchewan
Looks like you have the important stuff covered. What power level is your motor?
Oct 14, 2008
8,254
Yeah, bone stock in good shape should last no problem.
Street Sweeper22
Thread starter
Nov 18, 2017
145
I also got an external lock up kit and new transmission cooler lines. I got the new lines because when I put a new radiator in the threads were kind of stripped so I thought better safe than sorry. I hope I got everything covered. The shift linkage worries me a little bit.
Classic Truck Consoles Dixie Restoration Depot Mike's Montes UMI Performance
