Biggwaukegan said:how will i no if its uni bell or whatever you said. ?
Easiest way to ID Chevy vs. B-O-P is to look at the peak on the top of the transmission. A Chevy pattern CAN be bolted to a B-O-P (and vice-versa) with an adapter plate, but not enough holes line up to do so without the adapter plate. My $.02 - adapters are a last resort.
Buick-Oldsmobile-Pontiac (B-O-P) top is relatively flat
Chevy - top has a "peak"
Dual bolt pattern - Uni-bell .... not it has BOTH Chevy and B-O-P patterns ..... common to 200-4r kind of rare to find in the th350 .... I believe these are the ONLY GM aps witht eh double pattern. Number of bolts is the key to ID this one.
