Currently have a 200 4r installed in my 1984 Oldsmobile Cutlass transmission slipping so I have a turbo 350 I want to install just not sure if I need to change crossmember or drive shaft any help is appreciated thank you
Thanks Bob,Jack is on the money!
If I remember right the transmission crossmember is the same between the turbo 350 and the 200-4r. (Had to replace the one in my El Camino) The frame should have the mounting holes already in place closer to the front.
