2010 Sierra - need some info
Dayzedandkonfuzed
972
Anglemont, BC
So I'm looking at this 2010 sierra 1500 for sale. 4x4, 5.3 flex fuel truck, so it should have a 4L60 as far as I can tell. Ad says the trans is sometimes hesitant and starting to slip.
So worst case this rig needs a transmission. I'm not at all afraid of this job, but what issues might I run into sourcing/installing this thing? Are there many different 4L60's for that year? Are all the tail housings the same? Will I need to have the ecm flashed or programmed? If so how bad is that to get done? If it's not bad and I find a 6L80, would that be worth the swap or more of a headache than its worth? Should I attempt my own rebuild? Might I be lucky enough that it's just the PRNDL switch?
Feel free to answer any other questions I haven't asked!
Streetbu
Know it all, that doesn't
May 22, 2011
3,530
Central NY
Don't swap to a 6l80 unless ypu know the ins and out of the swap. There's quite a bit to it from what I understand. The current trans most likely needs a rebuild. Very common for a multitude of reasons. Personally I wouldn't put in a used 4L60E. You're asking for issues. Second, if you take it out and have it rebuilt, then install yourself, many shops won't cover their warranty. They want the install so the6 know the cooler, etc was flushed.
pagrunt
8,332
Elderton, Pa
If going to the 4L80, make sure the transfer case will bolt on. Also look into the AFM, I had my '08 Silverado drop one of the AFM lifters & ended up haveing to have a Casper reman put in just over 110K on it.
Dayzedandkonfuzed
Thread starter
Feb 9, 2010
972
Anglemont, BC
Thanks for all the info. Sounds like my best option is to rebuild the one in it myself, with the upgraded drum. Don't worry, I'll have an experienced transmission tech helping me. Or maybe I'll just yank it out pay him to do it.
This is assuming, of course, that this truck is still available when I get back from work next week. Man, trucks are hard to find right now.
Texas82GP
Just-a-worm
Apr 3, 2015
7,783
Spring, Texas
How are you going to drive the truck? If you don't abuse it, the engine is stock and the transmission is property built, the 4L65E that's in it should be ok. I don't know about "good for life" since clutches in all automatics wear in time. I recommend the transgo shift kit installed on the conservative side, especially with respect to number of spacers under the 1-2 accumulator. I suggest none or one at max. I also suggest the "The Beast" sunshell and the Corvette servo. The soft spot on these is the 3-4 clutch pack. That is likely where it is slipping. You can "stack the pack" by using thinner steels and putting in an extra clutch. I'm not sure how I feel about this mod. On the one hand, more friction material is good but on the other, The thinner steels concern me. I'd go with redline clutches and Kolene steels. They aren't that much more expensive.
My truck has a small cam in it (219/228 .525/.525 on a 112 LSA). It has the 5.3. It had headers, a high stall speed torque converter and 4.10 gears. It's 2wd. It's a regular cab/short bed. I'm guessing the 5.3 puts out around 400hp/400tq. That's a guess. The 3-4 clutch pack in the 4L65E started giving up at about 110k miles. I had the unit rebuilt along the lines of what I mention above. I drove it hard. I managed to start pulling the input shaft out of the input drum, which caused an internal leak, slipping, and burning up the clutches (I limped it to the office). It hung in maybe 20k miles. I had it built again, this time with a billet input shaft/drum. I shattered the output shaft on a wide open throttle 1-2 upshift. I was done. I swapped in a 4L85E. Best thing I ever did to the truck. You can read about it here if you are interested....
If the engine in the truck you are buying is totally stock and if there will be no abuse, you should be able to rebuild and beef up the 4L65E and have it hang in there. I won't try again. If you tow, avoid towing more than it is rated for. Either way, watch your transmission temperatures. You want it running 160-180. Frequent drain/refills will also help. I drain/refill the 4L85E in my truck every 10k miles. It's cheap preventative maintenance. It's overkill, but the fluid stays bright cherry red.
I don't know about swapping to a 6L90 but my guess is it is pretty straight forward since they came in those trucks. The biggest thing to overcome would be having the segment swap flashed into the TCM/PCM for the different transmission. That can be done by mail or email if you have or buy the programmer and pay the tuning service.
We run a fleet of 4x4 3/4 ton trucks from 2014-2020 that have the 6L90E in them. They seem to be pretty stout. Most all of those trucks have 180k-215k miles of commercial service on them. The transmissions in those trucks get serviced at 100k miles and again at 200k miles. So far, I've only had one fail, at 212k miles. It was in one of our trucks in Dallas. It broke down near a Chevrolet dealership so they took it there. We ended up just having a rebuilt unit from GM installed so I don't have any forensic data on what went wrong with the original unit.
Sorry for the long-winded response. I hope it helps.
Built6spdMCSS
3,434
Florida Beach
Advice I got from a GM mechanic was once a 4L60E has been rebuilt with a upgraded drum. They are good for life.
Lol... no.
I used to work in a transmission shop, built many of them things, definitely more to it to upgrade than an "upgraded drum".
Supercharged111
4,206
Colorado Springs, CO
I don't think a 6L80/90 swap is all that bad in a GMT900, no more involved than a 4L80 swap. It already has the separate ECM/TCM, correct GenIV hardware so everything will talk, and stock tunes out there that will work perfectly for this application. That said, I have no experience with them in terms of durability.
Dayzedandkonfuzed
Thread starter
Feb 9, 2010
972
Anglemont, BC
Now this I like the sound of.
mikester
2,728
Small town NY
On that vintage GM truck you should look closely at the frame rails and brake lines. Especially the two rear rails. The one over the gas tank the the one behind the spare. Both of mine look like swiss cheese. Same with our 2010 Yukon.
  • Winner
