2014 Champbell Hausfield 80 gallon compressor, It Works! Kinda
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The motor won't keep running. I would appreciate anyone with suggestions that I won't listen to?.....need to fill a few hundred pages ......:popcorn:
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
So the motor runs then turns right off? Pressure switch bad? Starter for the motor bad maybe...
Turbo Zach
2,534
5,874
After you get done dicking around you should polish the shaft and then half *ss rebuild it. Hope that helps.:popcorn:
  • Informative
  • Happy
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Replace the whatchamacallit.
  • Useful
  • Winner
ItsnotaGN
662
1,142
Colorado
I would change the air inlet filter and adjust the belt. I mean, if it only runs for a short period, there's no way to diagnose it.
