2019 Challenger Widebooty HellKitty (she's giving me the meatsweats...)
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Yeah, I pooped a little.
Reactions: 4 users
carnutjw
623
1,467
Excuse my ignorance, or impatience for not catching the answer to my question somewhere else in the thread, but are you getting enough heat in the tires? Looks like you're doing the burnout in first gear. Have you tried second for more wheel speed(and hence heat)? How do you know you're "there"? Could someone check tire temps right out of the box? BTW- looks like a lot of pedal pumping and sequence of events, I'm afraid I would get lost. Much respect for using the car the way it was built to be used.
motorheadmike
8,976
27,522
The car can do 60mph in first... how much more wheel speed do you want?! LOL. Second is an option. The issue wasn't traction, it is the bog off the launch. The left lane, in the "code brown" video, wasn't prepared for drag radials or slicks - it was the street tire lane. Hence blowing the tires off. The other issue was balancing tire temp to track temp - it was 54*F and overcast so super hot tires is not necessary as I understand it. COVID has really restricted the help you can bring with you up here.
Regardless, thanks for the input - and I am happy to beat on this thing as nature intended.
motorheadmike
8,976
27,522
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
That sucks that you can't take crew. Down here, most tracks allow up to 10 crew members, but no spectators. Hence, the new term "crewtators" has been coined. I had considered going to Cecil County, but their proximity to and ability to attract racers from the NY/NJ/Philly area has them throwing red C19 flags all over the place. Maybe that was their intent (discourage looky-loos), but I haven't had any issue with the tracks out here in the country. You just have to have a C19 form on file for NHRA.
Conversely, the dirt round tracks are operating with ZFG and allowing spectators.
motorheadmike
8,976
27,522
Quebec is borderline lock-down again, and has a zero tolerance approach. The challenge is it is putting the track at risk financially by not allowing spectators. The problem is people's nature prevents them from using good judgement if allowed in.
81cutlass
4,639
13,542
Western MN
On a side note from your tire post yesterday
Is the Hoosier QTP a stiff or wrinkle wall slick? Doing my research it looks like a stick car or a heavy car (both my 2+2 and your HC are both) should have a stiff wall. The QTP isn't marketed as a stiff wall but I think it is because it has a DOT rating.
Did you find out?
motorheadmike
8,976
27,522
Did you find out?
My understanding is yes, this the right tire for our application.
