22 inch rims
str8muzick
19
deltona florida
i would like to put some 22 inch rims on my 1983 pontiac grand prix....what modification do i need to do to the car? and whats the recommened tires size
Qdub24
1,796
785
Columbus, GA
I recomment 255/30/22 tires and just replace all your shocks, and maybe the springs. Make sure that your wheels are the correct offset.
shorty74
26
get 1.25 spacers for the rear or the rim will hit the frame. Also airshocks in rear and either twist in spring spacers in front or 1 1/2 inch lift cups. The lift cups will give it a smoother ride the the twist in knuckles just more money. Also the rear wheels will be close to the back of the door so i recommend adjustable rear control arms or eventually you will damage your drive shaft. I have a brand new set never installed that i got from universal car lift.com If interested PM me. Do all that and you will never have a problem with your 22's
T-TOP TONY
452
230
san bernardino, ca
im runnin 22 inch irocs with 2" drop spindles and 1.5 rear lowering springs. I have a 1 1/2" spacer on the rear cause the iroc wheels have a 0 offset. im running 255/30/22 in the rear and 245/30/22 in the front. The front only hits when i turn all the way so maybe you can put a 1/2" spacer for that. Heres a pic of mine
carmangary
633
2
How do those cars with those wheels ride? Seems like they would be a bit rough. I love my Cutlass Cruiser because it's like sailing the Atlantic.
T-TOP TONY
452
230
san bernardino, ca
yes it is a bit rougher but nothing i cant handle
