1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
231 swap to 350 / 383 stroker
Discussion in 'Engine / Swaps etc.' started by 79Firebird, Jul 15, 2017.
  1. 79Firebird
    79Firebird n00b
    Jul 15, 2017
    4
    Hey guys,
    I can swapping out a 231 from a 1979 firebird and installing a 383 stroker. My questions are about motor mounts and exactly what I need to bolt the engine in correctly. I am also pulling out the old tranny and putting in a turbo 350, as I believe will bolt in. Not sure of the drive shaft length though.... any way any help or pointers on this would be appreciated. Any ideas where to get parts would be helpful too. Thank you all in advance for the advise.
  2. Clone TIE Pilot
    Clone TIE Pilot Royal Smart Person
    Aug 14, 2011
    1,702
    124
    Galaxy far far away
    If your 383 is a SBC, then you will need to unbolt the 231 motor mounts off of your frame and install SBC motor mounts.
    • Like Like x 1
  3. 79Firebird
    79Firebird n00b
    Jul 15, 2017
    4
    Yes. It's a 350 block. Any idea where to get mounts?? Thanks!
  4. Clone TIE Pilot
    Aug 14, 2011
    1,702
    124
    Galaxy far far away
    The frame brackets you can buy at a auto store or catalog. You will want the four bolt chevy engine mounts, though you will only use 3 of the bolt holes on a G frame. The upper brackets that mount to the block either should have come with the engine or you will have to buy used on Ebay or elsewhere.
    • Like Like x 1
  5. 79Firebird
    79Firebird n00b
    Jul 15, 2017
    4
  6. pagrunt
    pagrunt Royal Smart Person
    Sep 14, 2014
    1,704
    704
    Shelocta, Pa
    Those will be what you need. For your swap just think Camaro for any other SBC parts needed.
    • Like Like x 1
  7. 79Firebird
    79Firebird n00b
    Jul 15, 2017
    4
    Thanks Pagrunt. Any pointers, links, or pic's you could send over would be awesome. Also like I said earlier I am swapping the tranny as well for a TH350. The rear end is a 3.42 Posi out of a 79 Z28. Does that sound like a good hook up to you? Just looking for advise. Trying to make a fun car to drive around town and make some noise. Thoughts?? Thanks again!
Loading...
Similar Threads - 231 swap 350 Forum Date
v6 Buick 231 A/C swap to Olds 350 Engine / Swaps etc. Jan 16, 2014
'79 Buick Regal 198ci to 231ci swap? Engine / Swaps etc. May 12, 2017
231 V6 Swap to 260 V8 Engine / Swaps etc. Nov 2, 2016
buick 231 swap to buick 300 is it worth it Engine / Swaps etc. Jan 11, 2014
Buick 231 to Buick 455 swap info Engine / Swaps etc. Dec 9, 2013
Share This Page
