231 V6 Swap to 260 V8
1980 Jay
n00b
Nov 1, 2016
4
Are these two fully compatible, and do I have to change any wiring. 1980 cutlass supreme coupe.
565bbchevy
9,590
12,611
Michigan
The Buick 231 and the Oldsmobile 260 are not a direct swap and you can't use anything off the V6 for the V8.
If I were going to trouble of swapping a V8 in place of V6 I would look for at least a 350 so you actually are adding power.
1980 Jay
n00b
Nov 1, 2016
4
Its coming from a 79 cutlass supreme
565bbchevy
9,590
12,611
Michigan
565bbchevy
9,590
12,611
Michigan
If you can get everything off a donor car it would make the swap easier but the 260 was designed as a reliable economy engine and that is all it is really good for, if you are looking for a big power increase go with something bigger.
1980 Jay
n00b
Nov 1, 2016
4
Yea it seems like a lot of work...Too much work. He said it would be an exact match. I really need a transmission and thought about just taking the engine and transmission to make it easier. Are 231 V6 th350?
565bbchevy
9,590
12,611
Michigan
You would want to verify what it is.
