Yeah that makes sense. It sounds like me with my car. Except, I don’t think I could sell mine.Not that one. More - than + with that particular car. But I learned a lot, and got a lot out of that. No regrets, either coming or going.
Timing is electronically controlled whatever play it has as long as the whole thing isn't rotating should be fine. That amount of movement is normal for a distributor that old.Hey bro, my distributor has some play in it. So when I grab the rotor i can move it clockwise and counterclockwise about an 1/8th inch even either way. Is this ok And will it mess with the timing?
I cannot figure out why I keep getting a intermittent code 42. Every time it flashes the engine stumbles. I’ve replace, cap, rotor, bushing, HEI module, plugs, wire and checked the wiring harness for shorts. Any ideas?Timing is electronically controlled whatever play it has as long as the whole thing isn't rotating should be fine. That amount of movement is normal for a distributor that old.
I solved most of the problems I’ve been having. There was a bell housing bolt with three ground wires loose. No more intermittent 42 code. There was another missing bell housing bolt and a loose bolt on the fly wheel. I guess when you buy a car for $200 out of a salvage yard this is to be expected. Does your car have those ground wires? It seems like these cars aren’t grounded very good at.Timing is electronically controlled whatever play it has as long as the whole thing isn't rotating should be fine. That amount of movement is normal for a distributor that old.
So what does it mean when I close the choke a little bit and it revs higher and it’s also reading 39-40 on the dwell.
Good work, you're getting somewhere.
I found my main engine ground bolt just sitting loose on the block, with the battery cable ring hanging on the threads.
There's also supposed to be a large flat braided ground running from the back of the block to the firewall.
Finally, it's worth taking the time to remove all of the battery cables, clean and inspect the cables, terminals and attachment points for signs of corrosion and overloading.
I meant when I close the butterflies on the air horn. As I slowly close them it will start to rev higher until about a 1/4“ gap and then it will bog dow. Sometimes it stumble off the line unless I feather it. Other than that it runs the best it has ever ran and gas milage has doubled.So what does it mean when I close the choke a little bit and it revs higher and it’s also reading 39-40 on the dwell.
