No need to remove the hood. Unbolt the hood shocks and the hood will tilt back on the hinges utility it rests against the windshield. Stick a thick quilt over the windshield and it won't crack. Saves the paint chips and effort of realignment on the backend.
Likewise, spend 25 minutes removing and reinstalling the header panel, no worries about banging or cracking when rolling the hoist, also let's you stand closer easier without as much leaning while doing your wrenching.
What other parts have you already gathered or are trying to decide on? Electric fans vs factory 307 fan shroud and top plate? Running a/c? Single vs dual exhaust? How to handle the crossmember? What trans, 3spd or od?
The th350 is the direct bolt on huh, what about the powerglide? i've heard there about the same length so it should basically be the same... however i'm still a not sure, I know my brothers friend has a spare Th350 but most likely would need to be rebuilt. i'll just have to end up gettin a drive shaft305 frame pads and mounts, elongate some wires, new transmission, normal stuff. The 3.8 (it's a buick if the dizzy is in the front, 229 chevy if its in the back) Buick has a BOP bellhousing, so the trans won't bolt up. A short shaft chevy Th350 will bolt in just fine though.
Why would you want a weaker trans like the power powerglide (compared to a TH350, both stock) with 1 less gear? And are you running an electric fuel pump/EFI? Or electric pump with a regulator?The th350 is the direct bolt on huh, what about the powerglide? i've heard there about the same length so it should basically be the same... however i'm still a not sure, I know my brothers friend has a spare Th350 but most likely would need to be rebuilt. i'll just have to end up gettin a drive shaft
I've read good things about the pg's as far as acceleration response and highway driving ... but i'd figure the th350 would be better as it can hold up much more abuse and is much more of an all around street/highway use type of transmission since my car will be a daily driver.And fuel wise, i'll end up going w the electric pump + regulator. What do u think about the PG's? I need a transmission that can last forever and hold up my daily obstacles like going to work & school basically. hahaWhy would you want a weaker trans like the power powerglide (compared to a TH350, both stock) with 1 less gear? And are you running an electric fuel pump/EFI? Or electric pump with a regulator?
As you can see, the PG is slightly shorter than a TH350, if the mount is in the same place it shouldn't be an issue. But, why a PG?
That'd be a TH350. They're everywhere, better gear ratios than a PG, and are innately stronger because they are bigger. How much stronger is up for debate, but they are tougher. A mild sbc (under 400hp) will work well with a good condition Th350 with a Trans-Go shift kit installed. That combo will last practically forever. Plus for a daily as you intend to use it, you will want all the extra gears you can.I've read good things about the pg's as far as acceleration response and highway driving ... but i'd figure the th350 would be better as it can hold up much more abuse and is much more of an all around street/highway use type of transmission since my car will be a daily driver.And fuel wise, i'll end up going w the electric pump + regulator. What do u think about the PG's? I need a transmission that can last forever and hold up my daily obstacles like going to work & school basically. haha
so far i've gathered the cross member, motor mounts, headers, also going with that duel exhaust 2.5 in, fuel lines since it currently runs on a mechanical fuel pump there'll have to be a lil conversion, I haven't decided on the transmission yet but i'm looking into the power glide trans.. definitely running ac on it, and an as far as the fan goes I seen a sweet chrome radiator which has the electric fans attached to it and man oh man it looks nice haha, it was on pro tuning.com .. Oh and also that ECUwiring harness! i still need that..and also a differential + drive shaft. Any recommendations though man? This is my first engine swap sooo i'll use any tips that I can get, thanks !
