3.8L V6 - vacuum, emissions, carb fix
brrian
269
272
51
Pittsburgh, PA
My SBB350 swap plans (all this) are on hold, mainly due to cost. I can't justify putting over $2K into a motor for a car that I'll drive maybe a few thousand miles a year. Maybe I'll get lucky & find a running local SBB350 for a few hundred bucks & I'll stick that in, or maybe I'll build the one I have someday, but for now I'm just keeping the V6. So:
The main to-do things on the V6 are to replace the valve cover gaskets (leaking) and rebuild the carb (running poorly, leaking gas onto the intake). I'll do both myself, the carb with Ken @ Everyday Performance's new book.
Today I found three more hoses on top of the engine disconnected and plugged. Some might have something to do with it running a bit rough, especially at startup. So, I'll figure all of that out & put it all back the way it should be. My smog pump is locked up. I don't WANT a smog pump, but if I'm going to fix all of this, should I just go ahead & replace it... isn't it a necessary part of the system?
Does anybody have a working pump they'd sell me cheap? ~$150 for something I don't want sucks.
& any advice about any of this is appreciated. I'll scour the forums for useful info before I get started.
Many moons go my neighbor had a 1980 Monte Carlo with the smaller V-8 [267?] and his smog pump locked up breaking the fan belt. Back then the stealerships wanted a king's ransom for a [new at the time] smog pump. I took it off, opened it up, and squirted lots of WD40 inside. I worked it back and forth and eventually it worked. There is a sliding blade inside that gets corroded and sticks. Open it and you will see. After that it worked fine for the life of the car.
Tomorrow morning's project. Thanks!
Also check the anti-back-fire valve. It may be leaking exhaust back to the smog pump and crudding it up.
Done! Spinning free. Thanks for the suggestion!
  • Winner
Yeah, just keep it running. Sitting engineless is a real demotivator.
