3.8V6 to 350 SWAP
83reeeegal
Oct 27, 2017
82
24
8
What's going on guys, it's been a real long week with school and work but i'm finally on break which means it's time to swap my 3.8! I just recently removed a 350 off my brothers dune buggy haha, engine doesn't seem really beat but either way I can't complain. I mean it's a FREE ENGINE sorta, all thanks to my brother {early x-mas gift maybe?} haha . Any recommendations of any good machine shops in the San Diego area or in So-Cal? Tips and hints are also greatly appreciated!
DRIVEN
8,074
14,533
*CENSORED*
Certainly don't need one but was just curious whether your block had the bosses for it. Better heads would probably be a better investment than a roller cam upgrade.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
flap tappet unfortunately, those roller cams are highly suggested? I definitely need to get a great set. any recommendations?
I have a brand new in box Comp 268xfi cam and lifters that would wake that 350 up, especially if you put some better heads on it or had them worked over.
If interested, PM me and I will get you some pics and specs.
454GrandPrix
429
818
Lehi, Utah
Don't waste your time or money on a roller cam if you're gonna keep using those horsepower-corking L05 heads. Seriously, the best recommendation we can give you is to toss those heads into the dumpster (at least you didn't pay anything for them, right?) and replace them with... well, almost anything would be an improvement. A stock pair of Vortec heads would be a fantastic budget upgrade.
Once you have those, they would be even better with a bit more cam than you have now. ;)
  • Informative
Reactions: 4 users
MrSony
6,828
6,736
Des Moines, Iowa
Keep in mind, stock vortec heads should have the valve guide bosses machined down to allow for cams with greater than .450 lift. Flat tappets get a bad rap nowadays from many, nothing wrong with them if you run good oil. If the break-in goes well, usually you're in the clear if nothing was assembled incorrectly. Build the engine for the gas you can afford. Ain't no fun having a 12:1 monster that gets 10gpm with 100+ octane being nearly triple the price of pump gas. Anywho... grab a cam (if staying flat tappet) with gentle ramp rates. Aggressive ramp rates and overkill springs are what flatten cams. http://www.lunatipower.com/Tech/Cams/CamProfileTerms.aspx
