3 inch tail pipes
1bad79
1,023
890
Allendale mi
My local exhaust shop doesn't have a mandrel bender and can't put 3 inch tail pipes over my axle on my cutlass and I can't seem to find any online at least not Buick or olds style ( 3/4) exit I tried a u fit it kit from flowmaster but it didn't work out what is everyone else doing? I'm in the Grand Rapids mi area if some one has a good suggestion of an exhaust shop they use thanks
oldsmobile joe
2,067
3,053
mpls
i know in my area of minnesota, exhaust shops don't have the equipment for mandrel bending. as a suggestion, have you tried looking at holley's 3inch exhaust that they made for the ls swap kit. its mandrel bent and your exhaust shop can do the final hook up.
joe
oldsmobile joe
2,067
3,053
mpls
this is the side exit, and it comes with hangers. bumper exit is available too. you just add the two pipe extensions.
565bbchevy
9,590
12,612
Michigan
You could make your own then you know it will fit, I made my 4" tailpipes out of mandrel bends I ordered from Dynomax/Walker and then welded them up and made them exit similar to a GN.
1bad79
1,023
890
Allendale mi
I
joe
I look in to this looks nicer than the kit I tried
ssn696
Living in the Past
5,543
6,662
Permanent Temporary
Heartthrob Exhaust is located in Litchfield, MN. They list 3" mandrel-bent exhaust systems. You'll have to prowl their site to see if you can find what you want. They may even be able to do custom work for you. The rep I talked to on the phone said that they manufacture the G-body true dual kits for Summit. http://heartthrobexhaust.com/headerdualkitsandaccessories.htm
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Geo's66
471
104
I have a kit found from from this site I bought that I didn't use- 3", side exhaust for my 78 Monte. Dynomax mufflers.. I'd sell if you're interested. North Chicago suburb
1bad79
1,023
890
Allendale mi
I have to go to vfn in a week or so to pick up my hood are you close to Addison Illinois?
