305 hesitation/miss-fire
mystre71
Apr 7, 2018
79
76
HI, I purchased a 79 malibu all original right down to the 305 with all the emission in place. I'm having an issue when taking off or going up hill, it looses power and there is a slight miss. Removed the cat, New battery and alternator (good voltage) I've changed the plugs (set the gap) , wires, cap, button, swapped out the coil, module, installed a new ERG, checked the timing, Checked for vacuum leaks, pulled the valve covers checked the springs and rockers. Timing was dead on, fires up at the turn of the key, runs fine while normal driving. What am I missing ? Any help would greatly be appreciated.
Jeff L
508
684
Southern AZ
Not sure if this will help but check if fuel is getting thru ok. Might be a fuel pump issue or line blockage.
mystre71
Apr 7, 2018
79
76
Thanks! I forgot to say I installed a new fuel filter check to make sure I was getting fuel. I probably should check the fuel pressure though....Also new air filter. This thing is being a pain! Have a buddy that's loaning me another carb to try, I don't really think that is the issue but need to try something.
85442/86buick
746
1,118
Perth Country , Ontario
so currently it has a Qjet ? filter in the right direction ? with the spring ?
just asking
mystre71
Apr 7, 2018
79
76
Yes sir. I replaced that filter as well. I'm now grabbing at straws, Have a buddy that's bringing me two carbs tomorrow to try, just to see if there is any difference. The thing fires right up, couldn't ask for a better running motor just taking off and up hill.
Clone TIE Pilot
3,859
2,611
Galaxy far far away
Sounds like either a sticking needle valve or sticky accel pump.
MrSony
6,828
6,736
Des Moines, Iowa
check float level. my car would do weird things like you mentioned, plus dribbling and cutting out momentarily around corners, sudden accel and decel, uphill as well.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I agree with Clone, it sounds like a weak accelerator pump. Put a few drops of oil down the rod of the accelerator pump and see if that helps. If it does you found the problem.
69hurstolds
8,195
17,596
Try the free stuff first, as previously mentioned. Then if that doesn't do anything, do the carb swap to see if there's any change, good or bad.
