hello, I have recently taken my cutlass to a mechanic and he pressure tested the coolant system. Pressure dropped very quickly, and there was no external leaking. He said it is probably a head gasket and he said probably around 800 dollars. Is it worth it to spend that just to keep the 307? are stock motors desirable in these cars? I am thinking of just running it into the ground so to speak, all the while saving for an engine swap because I was planning on getting rid of the 307 later on. If I should swap the motor, then which motor should I swap? are the 5.3 L Vortecs a good option? Should i try and find a chevy 350 or even an olds 350? what would be cost effective but still bring power?
