307 makes squealing noise
Joee533
Joee533
n00b
Jan 16, 2018
Hi i have a 87 442 it makes a squealing sound when idle and accelerating also have blown heads
I have a video of it running
Should i just rebuild or put another motor
motorheadmike
motorheadmike
4,763
Ottawa, Ontario Canada
The hamster is stuck in it's wheel.
Reactions: TURNA
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,075
Socialist NY
Kill it!!
lilbowtie
lilbowtie
2,842
Canton Mi
Timing is way off, and a little history when this started would be helpful.
blk7gxn
blk7gxn
629
The "squealing" noise may be from the power steering pump being low on fluid?
pagrunt
pagrunt
5,082
Elderton, Pa
I heard it chanting numbers: 4-5-5, 4-5-5, 4-5-5, 4-5-5...
Before we start spending you money take a look at all the belt drive stuff, adjust the timing, & even see if something is caught up with the flywheel/ torque converter. If everything is OK get ready to open up the heart.
Reactions: blk7gxn and Rktpwrd
olds307 and 403
olds307 and 403
5,515
Melville,Saskatchewan
Is the fan contacting the shroud? It could also be the torque converter cover contacting the flywheel. All the spacers must be in the right places and the water pump must be the right length or it will not work. There are 4 different water pump lengths for the Olds V8.
Reactions: blk7gxn
