307 non computer controlled timing.
Jimmy
Jimmy
153
Gulfport, MS
What should the timing be on a 307 olds after swapping to HEI distributor? I made the swap a couple of months ago but still think I may have a timing issue.
DoubleV
DoubleV
2,059
Medina Ohio
No. Initial timing can't be set unless you know the advance curve of the new distributor you put in. Most Olds engines with HEI's we're set at 20 which is the same as the computer controlled HEI's.
DoubleV
DoubleV
2,059
Medina Ohio
A stock 307 should like around 36-38 total. I would shorten the curve so you can run 20 initial and still get 36-38 total. For now, I'd run 16-18 initial.
When is all of your 20 in by? What about vacuum advance? How much? You running an egr valve?
Jimmy
Jimmy
153
Gulfport, MS
approximately 1800 rpm is when total is in. Vacuum advance is 10deg and no EGR valve.
TURNA
TURNA
7,856
Socialist NY
Did you swap the carb too?
olds307 and 403
olds307 and 403
4,558
Melville,Saskatchewan
Add more vacuum advance, about double. The 18 base should be about right, I find low compression Olds V8's love a lot of timing part throttle especially.
airboatgreg
airboatgreg
1,588
And down the rabbit hole he goes
Reactions: Clutch
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,885
Kitchener, Ontario
With no egr you'll have to back off the timing a coupld of degrees. The egr cools the combustion chanber and without that cooling the advanced timing can cause pre-ignition due to the heat.
