307 swap to 350
Skriblez
n00b
Mar 20, 2017
Can any body help me out I can't seem to reach the main bolt to get the 307 out to put in the 350 olds
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
The bottom two are easy to reach from bottom and the top two from the top. You may need to remove the crossmember and lower the trans to reach middle two bolts. It actually makes reaching all of them easier.
8,823
7,775
1970 Olds 350? What is inside it?
pmoore4321
107
97
Houston, Texas
I just did this today. Like stated before, the top two and the bottom two are easy. If you jack up the transmission tailshaft, it makes the top ones a little easier. The one on the passenger side about half-way up is a total PIA. I tried the "3-foot extension" method and couldn't get it. I finally pulled the transmission a little forward to get some room. I had to remove the trans mount. If I was going to put a SBO back in mine, I would leave that bolt out.
