I recently received a PM with concerns on this topic which has been discussed a long time ago on the forums. My response is below for the public to use as well or comment on:
"You should be able to get by with normal small block Olds pushrods for a non-roller cam. If you are going to an auto parts store, specify the pushrods to be for a 1975-80 350 Oldsmobile V8. they have large oiling holes and work fine for a stock type application.
You also need to be prepared to buy a new intake, unless you have the old 330 intake as well. The 330 heads are far superior to your 307 pieces, and the size of the intake ports is only one benefit. The 307 intake will bolt up, but the ports will be badly mis-aligned and you will have lots of problems when running. Buy an aftermarket intake, such as the performer rpm Olds small block intake, to get maximum benefit from your increased compression ratio and intake flow.
Also, now is the time to dump your 307 "peanut" cam. It is a smog type profile, and will just hold you back. If you want optimum mileage, run a stock 1973-80 350 Olds cam. For more performance with all stock parts, you should run a cam from 68-70 350, or even a big block. Use the 1970-80 Olds lifters for proper oiling.
Last, what year are those 330 heads? It may be necessary to grind or "slot" the pushrod holes in these heads to keep them from rubbing. The first 330 engines used a different angle for the lifters and pushrods, so the holes aren't properly aligned. You should also use the rocker arms that came with the heads if you have them.
Is there a thread for you to post this in? It is good to get this info out to the public when possible.
Let me know if you need anything else...
--Kris"
Feel free to comment! Thanks guys!
--Kris"
