I'm stuck at a crossroad with my swap!!
My 85 was originally a V6. When I bought it, it already had the 1st gen 350 and 700r4, but there were so many things halfa$$ed with the swap that prompted a complete do-over. The motor mounts were not made for a Gbody and poorly welded instead of bolted. Many other problems followed!!
Luckily, the compression test was good on all 8 cylinders, so after removing the AC/Heater box, the engine was painted along with the engine bay. Correct motor mounts were used and placed, and the engine and transmission were reinstalled. This is where a new set of problems occur.
The engine now sits about two inches further forward than before. The shorty headers now rub the frame. I like the additional room between the engine and firewall, but I have to resolve the header-clearance issue before moving forward. Plus, the headers no longer aline with the muffler piping.
I haven't measured the drive shaft, but I'm almost positive it will no longer fit. Sooo...I'm looking for solutions.
My first thought is to pull and reinstall the engine after moving the motor mounts back by an inch and a half or so. My second thought is to leave the engine as is and replace the shorty headers with long-tube headers, but Iwould still have the drivetrain issue.
Any suggestions for a wiser way ahead would be appreciated.
