Yea, im looking at 3 possibilities and getting prices right now. I was hoping the ones I found for 700 bucks would work but ill have to modify my power steering and altenator bracket locations, and buy taller valve covers for them. Im just not sure what to look for in a new set of heads to go with my lower end, since I cant find any info from when we built it.
Its all still a work in progress till I figure out which way im gonna go with it.
thanks for all the replies and advice
If it's $700 for the Camel backs, then don't buy them. If you already did, then try to sell them and good luck getting $700 for them (no negativity or sarcasm intended). The easiest way to go is a set of Vortecs, you'll need a different intake though and will also need the correct rockers.
If you can drum up $1000-1200, then a set of Speedway or Promaxx will be an improvement over the double humps and much better than what you have now. Included in the price I mentioned is a set of rockers and pushrods.
Your question about the pushrods cannot be answered until you decide on a head and rocker set up. Basically, a different length pushrod is required depending on what you end up with.
Also, why no love for ethanol in the gas? Don't be misled by all of the propaganda that every part on your car that contains rubber is going to be destroyed in the next year if you use it. It will actually help increase detonation resistance for a high compression build.
