1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
350 has spark and fuel but wont start
Discussion in 'Engine / Swaps etc.' started by 1984gbody, Nov 17, 2009.
Thread Status:
  1. 1984gbody
    1984gbody Not-quite-so-new-guy
    Nov 3, 2009
    13
    my 350 is getting spark and fuel but it wont start has anyone else had this problem and what could it be?
  2. pontiacgp
    pontiacgp Rocket Powered Basset Hound
    Mar 31, 2006
    18,892
    1,439
    Kitchener, Ontario
    take off the air cleaner assembly and cover the top of the carb with a rag so it blocks any air from entering and have someone crank it over and it should start
  3. illregal
    illregal Apprentice
    Nov 13, 2009
    65
    6
    try a set of plugs
  4. M.Bailey
    M.Bailey Master Mechanic
    Aug 26, 2009
    343
    Deer Island OR
    timing could be way off
  5. turbo78
    turbo78 Greasemonkey
    Nov 1, 2009
    224
    billings, montana
    is it popping through the intake, if so, the dist could be 180 out. if not, try advancing the timing a bit at a time until it cranks really hard, if it still dont start, you may not have adequate power coming out of your ignition module if its an HEI. i had that problem about 6 months ago. it would show it had good spark, but it just wouldnt kick ya know. i ended up replacing the module and everything inside the distributor connection wise. good luck. :D
  6. Bonnewagon
    Bonnewagon Comic Book Super Hero
    Sep 18, 2009
    4,943
    366
    83
    Queens,New York
    Ditto on the plugs. Pull one and eyeball it. Dry? Not getting gas. Fouled? Fuel flooded or oil getting to them. Fresh plugs are the best place to start.
  7. pontiacgp
    Mar 31, 2006
    18,892
    1,439
    Kitchener, Ontario
    I still say if he hasn't done anything to the car and it just wont start cover the carb with a rag to choke it to death and see if it starts...
  8. mkiiisupra
    mkiiisupra Master Mechanic
    Dec 28, 2008
    410
    16
    Versailles, KY
    Sounds like a timing issue. Pull the distributor, get number 1 to top dead center and go from there.
  9. Bonnewagon
    Sep 18, 2009
    4,943
    366
    83
    Queens,New York
    Wait. No one asked the right question. What did you DO to the car? If you came out one morning like usual and it was dead, that's different. But what if anything were you doing to the car?
  10. pontiacgp
    Mar 31, 2006
    18,892
    1,439
    Kitchener, Ontario
    awesome...someone else finally picked up on that....I assumed he didn't do anything since he never said he did....so that's the reason of my simple suggestion..... :D
Loading...
Thread Status:
Share This Page
