MULL0140 said:HELLO:
Note that the majority of the issues with the OLDS motors involve cooling issues. From the factory, an effort was made on the Firebird/TransAm to keep coolant system pressures down by using an "open" coolant system. Although a pressure-rated radiator cap is used, the unpressurized overflow reservoir vents coolant pressure from the radiator. Attempts to defeat/improve this stock coolant system have resulted in excessive coolant system pressures and blown freeze plugs.
Some mechanics indicate "movement" of coolant visible in the radiator shows water pump activity, but this may/may not be true. Movement of coolant in the radiator could also be an indicator of combustion chamber gases in the coolant resulting from a leaking/blown head gasket. There is an exhaust gas detector for coolant systems available to adapt to radiators.
Factory engineers normally don't deviate from known good systems. The OLDS motor was dropped from production early-on. If the OLDS motor is the only GM motor to have the water pump bypass tube in place, that indicates the engineers felt an issue at hand with the coolant system on the OLDS motor. Note that the Chevrolet small block water pump takes coolant directly off both sides of the block and does not have a bypass tube. This is a dramatic departure from the OLDS design.
Mark
Sorry, but again, you need to get an understanding of how the coolant flows in the block. The pump sucks coolant in from the bottom radiator hose and pushes it into the block through the two holes in the front cover. The two larger round holes near the top of this Olds front cover are the water pump outlet holes into the block cooling jacket.
This is EXACTLY the same coolant flow path as on a Chevy motor (or ANY other GM V8). The coolant then flows through the block, into the heads, into the crossover at the front of the intake manifold, and through the thermostat into the upper radiator hose. Again EXACTLY like on any other GM V8.
No, it doesn't. It "takes" coolant from the bottom of the radiator and EXPELS it into both sides of the block, JUST LIKE THE OLDS and Buick, and Pontiac, and Cadillac, and Ford, and Chrysler motors.
The "unpressurized overflow tank" is unique to Olds motors? Really? I guess the ones on my Chevy trucks must be something special. The pressure in the cooling system is governed by the radiator cap and the restrictions in the flow path. I have NEVER heard of any blown freeze plugs on an Olds (or any other motor) due to coolant system pressure. I even had the thermostat fail closed in my 69 Hurst/Olds and the 16 psi cap vented before anything else.
Really? The last Olds V8 was built in 1990 (it was also the last production car engine built in the US with a carb). The last Buick V8 was built in 1980. The last Pontiac V8 was built in 1981. You might want to check your facts.
Again, news to me and the millions of other folks who bought Olds-powered cars in the 1960s, 70s, and 80s.
