350 trans cross member
jcelk
365
270
i got a 82 elky with a chevy 3.8 and a 350c trans i am swapping in a 350 engine with a 350 trans with no lockup will my original crossmember work ? and what trans mount should i get ? thanks for your help
thanks I;m gathering up parts to make he engine swap go smoothly so replacing the 3.8 engine with a 350 engine the crossmember is the same best regards joe
Reactions: Sweet_Johnny
Just make sure that the trans mount and engine mounts are made of the same material or you can crack the trans bellhousing. Rubber engine mounts pair with a rubber trans mount, or polyurethane/polyurethane.
