ok i got an 85 t type and i pulled the motor out and bought a 97 suburban with a cracked transfer case plan on putting it in the regal and got a couple of questions.
can i use the whole front serpentine setup off of the suburban?
the water pump is reverse rotation, can i just hook it up to my radiator in the regal? v8 radiator
the motor runs awesome, but i noticed it has the spot where a mechanical fuel pump can go on, is it still a vortec or was it switched out before? car has a fuel pump for fuel injection i can just put a regulator right?
do i just buy a intake for a carb for vortec heads once i verify that they are vortec heads? then get HEI distributor right?
are motor mounts cheap or should i junkyard them
i think that wraps it up, motor should be out the suburban tomorrow maybe il show some pictures tomorrow
