ok, i have an 86 regal with no motor or trans and a 66 chevelle thats in dire need of body work, but has a well built 350/350 combo. I want to swap the 350/350 into the regal. What all will I need?
I know I need motor mounts. And possibly a radiator. Will the longtubes I have on the 350 work in the regal? Will I need to hook up any of the wiring harness to this engine? I'm going to run mechanical oil pressure and water temp guages. I'll probably rewire the charging system. I dont plan on getting this car to pass an inspection, I dont need to worry about that. Also, how will the throttle linkage connect? and the shift linkage to the trans? Any info is appreachiated. thanks
