I have decided to work within my budget and not go with the 403 build. It will be an iron head, roller cam, Olds 350 with a 4.125" bore and 3.5" stroke and a 2004R and 3.90 posi for my 70S. I already contacted Parkland Engine Builder's for machine shop price. I plan to have it stripped out by Christmas Eve and hopefully drop it off, there will be a wait. It will come at a great cost but there will be some benefit for all you guys, you will see.
My current parts run down
completely untouched 76 short block
330 forged steel crank offset ground to 3.5" stroke by Ohio crank.
Scat sbc 6" long, 2" journal rods and rod bearings
Clevite cam bearings
ARP 7/16" head bolts
ARP 1" longer 302 main studs for a Halo or girdle. FYI 302 main are the same length as 1-4 SBO mains.
1/2" CNC Halo, better made than the J+S Halo
Hydraulic Roller lifters
I also have Performer and RPM intake. I also have a 1" open aluminum spacer, modified for less air restriction. I may try the spacer on the RPM intake.
Fully rebuilt with a couple of thousand miles #6 iron heads 2.07/1.56 valves,with positive seals machined and the bowls opened with a bowl hog cutter. I am pocket porting them over the next couple of weeks, may do a separate thread.
Comp Cams 1.6 roller tip and Scorpion 1.72 full roller rocker arms, both for 3/8" studs, guide plates and 5/16" to 3/8" conversion studs.
Everyday Performance custom 800 cfm Qjet with adjustable APT
Mallory Breakerless distributor, adjustable mechanical and vacuum advance, set to 18 mechanical in by 2800 and 11 degrees of vacuum advance.
Mallory Hyfire 6AL with adjustable rev limiter, will set to 6000.
Serpentine belt drive and new Flowkooler Billet impeller, reverse rotation water pump on the way
New A body replacement aluminum/plastic rad
Dodge Stratus Fans
Good TH2004R trans, 86 model appears rebuilt, shifts perfect, needs upgrades.
PATC 2200 to 2500 stall, flashes at 2350 stall and deep trans pan with drain plug and a stacked 5000 rpm governor modified by me.
Sanderson shorty headers with custom 2.5" X pipe dual exhaust with shitty 2.5" tail pipes. Terrible job with a terrible price. I should have bought Flowmaster tail pipes and installed the tail pipes myself. Hack jobs like this is why I do all the work on my own cars, all 5 of them. I will add an O2 bung for a wideband tuner.
Remember these are the parts I HAVE, not what I want.
Dodge Stratus Fans
