What’s up guys. I have a 385 sbc shortblock ready for heads to be bolted on. The motor consists of a 4340 rotating assembly. 6in rods with je/srp 11:1 flat tops (with 64cc heads) cam is a custom grind solid roller from Cam Motion and the specs are as follows
613/568
246/252 @ 50
110 LS
23 valve lash
35-6500 rpm range
Heads are eBay 220cc el cheapos
Flow numbers seem a little too “advertised” but they are
@100 68-53
@200 143-112
@300 196-163
@400 244-199
@500 262- 226
@600 299- 239
If these flow numbers are in fact what they say they are how streetable would this combo be? Not really looking for streetable though, the car is a 1985 Cutlass full weight (3500lbs give or take) and will be driven mainly on weekends and an occasional trip to the track. Transmission is a pretty stout th350 with 3500 stall converter with 411s out back.
My only concerns is the heads being too big? Any suggestions would be greatly appreciated. Thanks
613/568
246/252 @ 50
110 LS
23 valve lash
35-6500 rpm range
@100 68-53
@200 143-112
@300 196-163
@400 244-199
@500 262- 226
@600 299- 239
