ALso why does These spectre stud curves ?View attachment 66030 View attachment 66031 I have the spectre air clean but the stud to short and I couldn't put the bolt on and tighten it,and when I took the air cleaner off the bolt wouldn't even tighten on the stud can somebody send me links on longer studs
Mines is straight
You think autozone should sell longer studs ?It curves because it's for a offset base , normally to move air cleaner forward for distributor .
As for the stud itself why not buy redy rod the size you need , be cheaper.
