4 Speed conv. w/Hyd. Clutch
MadMonte
102
York, Pa
Hello everyone! I just purchased a Super T10 26 spline 3 groove trans for my 83 Monre Carlo. I know fitting full length headers with a mechanical setup is a PITA so has anyone used a hydraulic setup that is home built instead of purchasing the expensive kits that are available? I was looking at possibly using a camaro clutch master and a ram clutches hydraulic throw out bearing and slave. Any info and pics helps. I'll reply when I can. Thanks!
airboatgreg
2,867
3,115
We i was doing the research to convert my 82 El C a lot of people were using an F body set up
gnvair
1,102
1,304
I run long tube Hedman headers with my factory mechanical linkage with no clearance issues and it was NOT a PITA with a correct set of headers. It seems guys with the hydraulic clutch set ups have more problems.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
me too, I'm using a McLeod throw out bearing. Make sure you put a doubler on the fire wall cause it will crack without one.
  • Informative
39F
530
602
Pittsburgh PA
I'm using the same setup as you using Camaro slave, ram throw out bearing super T10 , couldn't be happier ,my clutch is a twin disc McLeod ,stock bell housing
MadMonte
102
York, Pa
What pedal setup are you using? it would be awesome if you could provide some pictures and a part number for your FBody parts. Thanks!!!!
