patmckinneyracing said:
Summit brand. Cheap, good all around camshafts and parts. In order to save money, stick with the heads you got, they're capable of making 400hp easily. The valvetrain you'll probably want to beef up to a .500 lift capable spring and the stamped rockers will be fine. I personally like edelbrock for my intake and carb parts.
On ebay, there is a chinese msd knockoff distributor that makes 45,000 to 60,000 volts and is an excellent distributor. It was highly recommended by my engine builder who builds for NASCAR and its only 45$. As for headers, the best I've seen to fit our cars is flowtech but I'm not sure if they make them for a pontiac.
Basic theory is that you should be able to make 1 hp for every cubic inch. I'm using a summit .442/.465 camshaft and it has plenty of lope and torque down low. I stand by this cam and other members on this board started using it and have been very happy with it.
You get what you pay for.
Cheep, Good, Fast; you can only have two.
I cant say Im the biggest fan of pontiac motors anymore, but the edelbrock rpm heads that are available for ponti v8s do the job pritty well of making between 4 and 500 horse. Out of the box they flow:
Compare those with the RA3 and 6x heads:
These heads will allow you to make 400 horse and be very mild on the cam you choose. Of course you need to get a cam with lift enough to take advantage of the heads . Stay away from summit brand cams, Ive spent enough time cleaning up the damage caused by cast core cams. If you can get a billet core cam get one. No question about it. The last thing you want to do is wipe a cam and find out you scored the bearings and have to yank the engine and start over. Not only are cast corse potentially dangerous in that regard, but summit brand cams generally will never meet advertised specs. Measure what you get and id be willing to put a few dollars on it not being whvery close to what was advertised. Stay away from anything procomp (except perhaps their carburetor parts, I haven't heard or experienced anything bad with them).
The factory heads will get you to the 400#, but you will have to go a little bit more agressive on the cam than you could with a better set of heads. First off what heads are they? 6x, 4x RA3 RA4? With the exception of the 4x they all flow relitively the same, right arround 215-235 cfm at .500. so 50 to 70 cfm is really nothing to scoff at. That could mean the difference of having a higher compression 93 gas engine to barely make 400, or running a mild 87 gas engine and exceeding your goal of 400.
Either way, dont be cheep. Thrifty is good, and look for deals but dont be
cheep...it winds up being more expensive.
