i am building a 406 SBC engine it was for strip/street use but now it will be for WE fun not realy strip
need to go in a cutlass 1980
dart little M
wiseco pistons flat top (+5.4 CC cups)
scart i beam 5.7 rods
scad 3.750 crank 4340
AFR 220 comp package heads (valve springs for solid tapped cam) 75 CC
Rocker Arm; Ultra Pro Magnum 1.6 and 1.5
4500 stall converter
th400
isky cam
no idea on the rear gear but it is a posi drive
tires 275/60x15
is thise set up any good for street use ore is the cam to mutch
i am willing to change cam and stall and also rear gear but keep it usable for highway use
if not to expencive and a real benefit i can change to roller lifers but it need to be worth the money
dart little M
th400
isky cam
tires 275/60x15
